Toggle pop up box
Can text blaze snippets work inside the text blaze pop up box that appears when you select a toggle or have a text field? If not this would be a fantastic feature I would love to see.
As of right now, snippets don't work within the Text Blaze form pop-up window.
Though, you could use {import} if you want to use a snippet within another snippet. For example, you could have a toggle field where, if toggled, another snippet is imported.
Let me know if that makes sense and if you have any questions.
Thanks for the suggestion @echapman . You can vote on the feature request here
