Hi all,
I am looking for a way to utilize {urlload} and to be able to wrap the link and title of the content. So far, I am able to extractregexall and then split all Titles and URLS, however, I am wondering if there is a way to wrap each Title with the URL using {link: {=URL}}{=Title}{endlink}. Is this possible using the {Repeat} function? If so, any suggestions?
Please let me know if the clarity is needed. Thanks!
Example so far:
Hi Josh, is this similar to what you're looking for? I used the repeat command with list comprehension (docs):
Hi @Gaurang_Tandon ,
Thanks for your response! This isn't quite what I am looking for.
I am looking to utilize the {urlload} command to only load the content Titles + URLs for a list of references. Currently, I can load each individually as separate items, however, I am trying to hyperlink the title with the corresponding URL.
For example, I am using the {formmenu: name=search} command to dynamically return results from a site directory, which I can do for each item but at the moment I've basically created two separate lists.
What I have done:
Search: {formmenu: name=search; default=How to Code}
Content Title: "How to Code?"
Content URL: "https://example.com/how-to-code"
What I want to do for all articles on a page not just one:
Content Title+URL: "How to Code?"
I was wondering if somehow utilizing the {Repeat} command could solve for the repetition (e.g. wrap Title A with URL A, Title B with URL B, etc.) while including the {link} command as well.
Does that make sense?
Hi Josh, I converted my earlier snippet to now use the dynamic link command. I hope it's useful now:
