Hello Blazers!
I want to know how Usage stats calculations are affected when importing snippets into other snippets. Here is a crude example for the sake of easy math
Let's say I have 1 snippet on its own that saves 2 minutes of time, and another snippet on its own that saves 30 seconds of time. I want to import the 2nd snippet into the first snippet so my users have to only run 1 snippet. Would Text Blaze calculate this 1 snippet as now saving 2 minutes and 30 seconds? Or, does it only calculate the time saved for the snippet the user initially triggers?
At this snippet and individual user level, this is a very minor thing. However, the compound affect of scores of users over half a dozen teams would be astounding.
Thank you for any insight!
-Brad
