Hello,
I want to use {clipboard} as a hyperlink, but it doesn't work. The Hyperlink contains only the text "{clipboard}" and not the link in my clipboard that I need.
Does anyone has a idea to solve this problem?
Hello,
You can try in two ways:
{link: http://example.com/{clipboard}}website{endlink}
You can read more about the {link} command here:
Thank you for the hint. It works with:
{link: {clipboard}}{clipboard}{endlink}
