When using a link in a template
When I use a link in a templates is adds an additional space in my code.
Here is an example of what i want to insert:
Insurance Option - Some Insurance
Hey You!
This is you from Some Insurance. I finished reviewing your insurance options.
First off, I want you to go through this article our owner put together because there's a lot of factors causing insurance to become more difficult and more expensive here. We are a very hard market for insurance companies, most of them don't break even. Here's the link to the video: www.google.com
As soon as I take out the link the last line break at the very end disappears. What's going on?
Hi Noah, thanks for reporting the issue.
  • Can you please share which website you're facing this issue on? Can you please try the same snippet in the main textbox of the Text Blaze Dashboard and let us know if you face the same issue there?
  • Is the line break coming from the parent website or is the line break part of your snippet? Can you share your snippet so we can better check it.
Best,
Gaurang
