Ability To Have Multi-Line Error Commands
When creating Error commands - especially the newer variations that aren’t actual errors - I want the ability to force multiple lines instead of relying only on text wrapping
Method 1: Both messages in 1 command capsule
  • The only option is to communicate information in sentence or paragraph form.
  • Requires Method 2 to communicate listed information or points, which users handling large amounts of information can more easily digest.
{error: This is the first thing I want to tell the user. This is the second thing I want to tell the user.; type=info}
Method 2: Both messages in separate command capsules
  • Results in an unnecessary additional “!” icon.
  • " ! " icon and visual gap between capsules is unsightly and gives user impression of topic change.
{error: This is the first thing I want to tell the user.; type=info}
{error: This is the second thing I want to tell the user.; type=info}
Here is a crude mockup of my idea:
  • Keeps all topic-related content within 1 command capsule. :white_check_mark:
  • One “!” icon denotes to the user that this is all related information. :white_check_mark:
  • Ability to force multi-line entry allows content to be chunked for efficient user interaction. :white_check_mark:
As for attempted solutions, I've tried pressing the [Enter] in the editor. Also, using the Advanced Editor mode, I've tried pressing the [Enter] key a couple times as well as inserting "\n\n\n". None of these work. However, in both editing modes, pressing the [Enter] key does show the line breaks.
Thank you for considering this idea.
-Brad :fire:
Hi @Brad_Hedinger.
Thanks for sharing your thoughts with us; we always appreciate your valuable suggestions. I'll check with the team and see if there's any possibility to support the new lines in the error command.
Support for multi-line errors is now in the v3.3.14 extension (as well as in the desktop apps). I'm marking this request as solved. Please try it and let us know if you face any issues using it.
It's working great! Thank you!
