About the Questions and Help category
Hello, I have been using Alfred on my Macbook for several years and have lots of snippets that I have created over time. Is there a way to export my Alfred snippets into Text Blaze?
Hello.
I'm interested in an autotext tool and I really liked Text Blaze. I need it for a specific use and, with my knowledge, I haven't been able to configure it. Therefore, before deleting the app, I would like to make sure that there really isn't a way to configure it for my use.
Let me explain:
I work in a law firm and I have several standardized procedures ("step by step") divided into 4 categories. If I could give an example, they would be something like this:
    1. comercial (several procedures and snippers here)
    1. administrative (several procedures and snippers here)
    1. judicial (several procedures and snippers here)
    1. liquidation (several procedures and snippers here)
It turns out that in each category there are several procedures. Therefore, it is difficult to memorize each of the shortcuts.
For this reason, I would like to type a shortcut (for example: "/") and this would open something like a MENU where I could navigate, with the mouse, between the categories above and select the snippet I want.
Is there any way to do this? If there is, could you explain it to me so I can try?
Hi there
I'm using text blaze in google docs and noticed a couple of issues.
The 'place cursor' function doesn't seem to work and when inserting a snippet with a table the table formatting is changes when inserted. Is there any way to resolve these issues?
I was also wondering if is there a way of carrying over a defined form text field to subsequent snippets. Eg if I'm inserting multiple snippets throughout a document and I want all the 'name' fields to have the same value without having to type it each time.
Thanks
How can I get Text Blase to work in open office documants? How can I get the program to stay on?
Hi @jimrwhitelaw! Welcome to the Forum :wave:.
If I am understanding you correctly, it sounds like you are using Office outside of your web-browser. Is that correct?
If so, we have both a Windows and Mac app that you can use to be able to insert snippets into any applications you are using. You can download those here. You can download the Mac app here.
Oliver, yes I use Apache OPen Office and your link made it possible for me to use Text Blase in it, Thank You
Hey guys,
My question is on Inserting Dates, when i do it on text blaze the dates are perfect but when i add the snippet to an outlook email the formatting of the date is all messed up. Is there a way I can fix this?
I am not sure what i am doing wrong
Hello, how do i make the default new snippet blank instead of "Replace me with the text you want to insert..."
HI Scott! I wanted to know if TextBlaze is HIPAA compliant as I am planning to integrate it in our healthcare practice - which means handling protected health information.
Hi - none of my shortcuts are working today. I've restarted Chrome and they are still not working. I've been using TB for 4 years, so I don't think it's not operator error, LOL! They are not working in any format. Bill is paid, so that's not it...Anyone else having issues?
Hi Elizabeth,
We apologize for the inconvenience. Can you please try to reinstall the extension from the Chrome Web Store?
Hello,
I was hoping to create a snippet that includes many things to be filled out on a quick basis. For example if I have below snippet:
Dry mouth: ***
Humidifier use: ***
I would like to be able to hit the key "F2" or "Tab" or some key to be able to move from *** to the next *** without having to use my mouse to do so. Can that be done?
My text blaze is not working . when i enter my short cut command the text blazed does not appear. However what ever I cut and pasted previously will appear instead . Everyone on my team is having the same problem . Do you know how to fix this ?
The setting for your email may have dates configured or formatted to be shown that way. Check your settings for your email.
Do we have anything for Firefox browser ?
Is there a way to repeat a text field below current text field if the current text field isnt blank?
Is there a way to add a click element in the ai Blaze output like how it works in textblaze?
hỗ trợ thu hồi vốn treo
Hi, I shared a folder with my colleagues, but they are unable to see the share. What am I doing wrong?
