I'm inserting a text strong from Data Blaze using this:
{if: catch up hours
=0}{else}{=catch up expected
}{endif}
So if there are no catchup hours it should insert nothing. Does that approach require a "0" in the cell. What if the cell is blank rather than having a xero? Would it better better to use
{if: catch up hours
=""}{else}{=catch up expected
}{endif}
'catch up expected' is a line of text and I want to insert one line break before and after it but I can't get the syntax right. Do I use concatenate? What do I use for a line break? \n or \s or $1
(I'm new to grep)
I tried this but it doesn't work:
{if: catch up hours
=""}{else}{= \r catch up expected
\r}{endif}
Thanks
