it would be great to be able to add data into airtable directly instead of data blaze that is it offers less integrations than airtable.
You can integrate with the Airtable API using the {urlload}/{urllsend} commands:
However, it's pretty technical to do. We built Data Blaze to make these sort of tasks much easier that would ever be possible integrating with a third-party API like Airtable. What features are missing from Data Blaze for you?
We try to use airtable in order to be able to relate data with our other tables.
We like notion to frictionless capture data from any device and whalesync to sync it to airtable, where we can relate all our business tables.
