Can you allow Sufix or Prefix in Number field in Datablaze? It would be helpful to indicate whether its currency value or something else etc.
Hi @Pratik_Shah
Thanks for your suggestion. What about using formulas here? You can create another formula field and concatenate the number with the needed postfix or prefix, for example: "$" & Number
Yes, I understand we can do that using formula. But it would be best to have it inbuilt
We'll think about it too, thanks for all your creative suggestions.
