Hello, while in Outlook, if I use a snippet, it shows this pop up window, which is something I had not experienced before. Let me know if there is a way to stop this from happening.
Hi Jamie! The popup should dismiss within 10 seconds after appearing. Does it not disappear after 10 seconds?
Also, it should only appear in the bottom right corner of your screen, and with a small size compared to the rest of your screen size. Is it very large compared to your screen size?
Thanks for replying Gaurang. It does disappear within 10 seconds but for me it is too long and it seems intrusive. The size is not too large, but large enough to annoy me. However, if there is no way to get rid of it, I understand.. I really appreciate your dedication to reply promptly to our questions. ::
Thanks for your feedback Jaime. We appreciate it. There is no way to remove the popup right now. We'll be open to more feedback in the future on this.
