We use Text Blaze to input our electronic medical records. Due to changes in the electronic medical record system, the addresses of the input fields often change, and I was wondering if there is a way to batch replace the necessary parts with Text Blaze code? If I copy it into an editor, I lose the tabular information, etc.
One way you can do is export the snippets, open the exported file in a text editor and replace the parts you need.
And then reimport them deleting the original snippets.
To avoid the risk of corruption, you can duplicate and save the original exported files.
@VinodGubbala
Thank you very much, the specifications of electronic medical records change frequently, and it is troublesome to change the address of the web importer each time. It would be nice if all snippets could be changed at once.
Thanks for the feedback. We will think about how to improve this experience.
But currently, exporting the snippets and replace in the exported file is the best solution. Please let me know if you like step by step guide to do this.
