Any way to set shortcuts as case sensitive?
If I type in CC I know I can use the text expander for a short cut I create
But if I use cc I don't want anything to populate
Is this possible? Any way to set phrases to be case sensitive?
You could do something like the following in a snippet whose shortcut is "CC":
{if: {snippet: trigger} == "CC"}my snippet{else}{snippet:trigger}{endif}
It will insert "my snippet" when you use "CC" otherwise it will just echo back what you typed when you use "cc" or "Cc" or "cC".
In general though, this isn't a great way to do things in Text Blaze. It's best to make your shortcuts unique like ",CC" or "/CC".
I appreciate the fact that Text Blaze is NOT case sensitive (that can be a major pain!)
Far simpler to just change the shortcut as Scott advises.
