ASCII code rendering
In text blaze is it possible to rendering ASCII equations with code to copy on other sites
I think you should be able to, can you post example here?
You will likely want to set the font of the equations to Courier New, a mono-space font. You can do so in the Text Blaze snippet editor here:
1
if i wrote input i want to get output format ASCII code rendering is it possible
Hi @sekhar.asapu , this format is commonly implemented using Mathjax. The output is either an HTML or image. Do you want HTML output or image output? In most cases, this rendering should be done by the target website itself, not by the client (you).
So can you please elaborate on which website this is, and why specifically you need to do the rendering yourself (instead of letting the website do that), that would be useful to understand alternative solutions.
Good evening. I need to be able to have something similar to what is rendered above as a note with in a snippet. Can you help?
Hi @sara_jacks welcome back! Can you please elaborate on your use case a bit? Do you intend to render math formulas? On which website will you be inserting this snippet?
