hi! I am wanting to create a snippet that allows me to pick an option and it will then turn into a snippet.
For example: On the snippet, I pick the phrase "flagging complaint" and it changes to
"Complaint: input the reason for the escalation
Reason: input info by customer"
Any help on this?
I want it to pick the word or phrase and it pastes the saying for it.
scott
2
Hi, and welcome to the forum!
It looks like this is what you're looking for:
You can select an option from a formmenu and the text to insert will be chosen based on that.
Once you have set up your formmenu, you can click this menu option to quickly create and if-else command to go with it:
Let me know if this helps!
