Australian localisation (en-au)
Could you add a Locale & formatting option for Australia?
Down under we use the metric system, date format dd/mm/yyyy and currency is dollars $. So a bit of a mix of gb and us formats.
I noticed this because I've got my account set to en-gb, however when I use calculations that use money formatting, the $ sign ends up being a pounds sign which we dont use in Aus.
Hi @anon79203624 Welcome to the forum! :slight_smile:
Thanks for posting your request. Our team will look into it and hopefully implement it soon.
Another vote for this please. The example output should look like this:
Example date: Wednesday, 13 December 2023 09:27
Example currency: $43,123.27
Hi all! This should now be available. Can you please check and let us know if it works well for you? Thanks :slightly_smiling_face:
