I have a formparagraph called "Message" that I use to craft messages that I want to send. However, my messaging software has a limit of 185 characters per message. There are many times I need to send a lot more than 185 characters though. So, I need whatever I type in my Message to be automatically broken up into outputs that are each capped at 185 characters. For example, if the message I type has 420 characters in it, I would end up with 3 outputs where Message 1 shows the first 185 characters of my message, Message 2 shows the next 185 characters of my message, and Message 3 shows the remaining 50 characters of my message.
I came up with the following snippet that seems like it may be headed in the right direction, but it feels clunky to me. I made the default formparagraph content a ChatGPT generated prompt that is 420 characters to keep with the above example.
{note: preview=no; insert=no; trim=yes}
Variables:
Message Length: {message_length={=len(message)}}{=message_length}
Message Length - 186: {message_length_minus_186=message_length-186}{=message_length_minus_186}
{endnote: trim=left}
{formparagraph: name=message; cols=65; rows=8; default=At Creative Solutions, we blend work with a touch of fun to keep things lively. Every Friday, we host a "Cheerful Chats" where we share jokes, enjoy snacks, and catch up. This weekly ritual not only lifts our spirits but also sparks new ideas and strengthens our team bond. We have found that these moments of lightheartedness make our workdays more enjoyable and enhance our overall productivity. Cheers to fun at work!}
Character Counter: {=message_length} {if: {=185-{=message_length}<15}}
Characters Remaining: {=185-{=message_length}}{else}Characters Remaining: {=185-{=message_length}}{endif}{if: (186-{=message_length})<=0}
{error: MAX CHARACTERS REACHED!; block=yes; show=default}{endif}
Messages 1 and 2 below are a test of having Text Blaze automatically take what you are typing in the field above, and splitting it into 2 messages, as you type, if it exceeds 185 characters.
Message_1: {message_1=left(message,185)}{=message_1}
Message_2: {if: {=message_length}>185}{message_2=right(message,message_length_minus_186)}{=message_2}{endif}
See, the split seems to work fine for Message 1, but I have not figured out how to do this for a 2nd, 3rd or even 4th message if needed. Also, it would be ideal if the automatic split happened at a word break before hitting the 185th character in each message. How would any of y'all go about doing this? Love to hear your ideas!
