Hi there,
Wondering if there's a way to disable the automatic indenting whenever a bullet point or number is added to a given line?
Thanks
Hi there,
Thanks
Hi, welcome to the forum!
Unfortunately, it is not possible to disable that currently.
Note that auto indent only occurs when you start the line with both a dash and a space in that order. Is this an issue you frequently run into? Can you give us a little more insight into the kind of data you're trying to work with?
If you run into this rarely/occasionally, then you can 1. "un-indent" the list by pressing Ctrl-Z (undo operation) or pressing backspace 2. write a hyphen but not follow it with a space so it would not auto-indent (add the space later once you're done writing the remaining text)
