I wanted to know if I can do the following?
I would like to grab a # X ( # of packages arrived at station) from a web page and divide that by (Y) # of packages processed in 1h that number (minutes) should then be added to the current time and state at what time the current packages arrived are finished.
Initially it is fine to enter both values X and Y manually, into the snippet in the long run I would like to grab X from a webpage and enter Y manually or grab from a webpage but not too sure yet.
Is this something that is feasible, if so would I need the pro version to do this and how would the snippet, formula look like?
Yes, the ability to pull from another website is very straightforward. You can use the website feature built into Text Blaze's dashboard - Text Blaze Dashboard 2024-0...
To demonstrate, I created a snippet that pulls values from my LinkedIn profile (Profile viewers and Post Impressions). I pulled these values using the Website feature in Text Blaze.
Once, I created these values, I was able to enter them into a formula that calculated the following value 2.57823129251701
I posted the snippet here - Linkedin Profile Snippet - #2
I am unsure what you want to do here "processed in 1h that number (minutes) should then be added to the current time and state at what time the current packages arrived are finished."
But once you have the data from the website you can apply any additional calculations.
The "Formula feature" of Text Blaze requires the Business tier of Text Blaze.
Please let me know if you have any additional questions.
Best,
Mike
