Bug Report : Extension in Vivaldi/Fedora - Dashboard Link does not work
Running TextBaze Extension in Vivaldi
6.2.3105.48 (Stable channel) stable (64-bit)
and on Fedora 38.
Text Blaze is working great, with the exception of when you click on the Extension Icon, the links in the header don't work.
They simply don't work/do anything when you click on them, unlike the Chrome version.
Not a Major thing but thought I'd log it.
Hey Andy, good to see you back in the forums.
I tried this on Vivaldi (same version) on macOS (13.6) and also on Ubuntu 22.04. (I don't have Fedora at hand).
I opened and closed it a dozen times, and the buttons did fail for me twice. Not only these two buttons, actually, none of the snippet links worked either.
That is a really strange issue. Quick question: does this issue only happen when you have a specific website in the background?
Thanks @Gaurang_Tandon , been busy with real life :slight_smile:
For me it happens on most web-pages webpages. Here are a couple for example where it does not work
https://community.blaze.today
I could not find one where it was working, although I'm 99.9% sure it's worked at some point.
Happy to provide any more debugging info.
Installed Extensions
GNOME Shell integration
1Password
UBlockOrigin
Textblaze
Google Docs Offline
Vivaldi Version Info
Vivaldi 6.2.3105.48 (Stable channel) stable (64-bit)
Revision 1c6fcd98cf165864e5c4ba03424f8512b597f16b
OS Linux
JavaScript V8 11.6.189.20
User Agent Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36
Command Line /usr/bin/vivaldi-stable --flag-switches-begin --flag-switches-end --desktop-startup-id=fedora;1695304370;248092;3568_TIME30177 --origin-trial-disabled-features=WebGPU --save-page-as-mhtml
Executable Path /opt/vivaldi/vivaldi
Profile Path /home/darkufo/.config/vivaldi/Default
Fedora Info
Linux fedora 6.4.15-200.fc38.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Sep 7 00:25:01 UTC 2023 x86_64 GNU/Linux
Kernal: 6.4.15-200.fc38.x86_64
I'm running KDE Plasma - plasmashell 5.27.8
Thanks, I'll take a look. In general, Vivaldi is quite inconsistent with Chrome. For example, it doesn't have the Chrome omnibar code, so the tb<space> keyword trick doesn't work in Vivaldi's address bar (but works in Chrome's address bar)
