Calculating # of days in a given month
I previously asked this question, but the snippet is no longer working.
I would like to calculate number of days in a given month based off of a date and also number of days for the next month.
Example:
Input 10/23/2023
Outcome:
October = 31
November = 30
Help! And thank you in advance. :slight_smile:
@Stephanie_Bouldin great question, I was just working on something similar to this for another customer... this will do what you need it to do:
{formdate: YYYY-MM-DD; name=starting}
Days Selected Month: {time: D; at={=starting}; shift=>M}
Days Following Month: {time: D; at={=starting}; shift=+1M >M}
If you need the results to be usable in another equation, like for totaling those number of days up easily, you can save the results as variables to use:
Days Selected Month: {current={time: D; at={=starting}; shift=>M}}{=current}
Days Following Month: {next={time: D; at={=starting}; shift=+1M >M} }{=next}
Total number of days between the two months: {=current+next}
Thanks so much @Andrew_Hall !!!!
