Call icon blaze text
Is there any way in blaze text to make some active icon for this program in gmail. I don't want to use the shortcut /... just select from among folders. I know you can right-click and select blaze there, but I would like it to be possible to call blaze using an icon. I will add that I am using gmail on win11 as an application, so the puzzle icon at the top is not visible like in chrome.
Hi @e-markizy_sklep Welcome to the forum! :slight_smile:
Thanks for the question. Have you tried using the keyboard shortcut for the Text Blaze extension? You can open the popup assistant from any webpage by typing Ctrl-Shift-Space on Windows. You can change this shortcut by going to this page: chrome://extensions/shortcuts#:~:text=Text%20Blaze
The popup will show a list of snippets, and from there you can choose the snippet you'd like to insert. Let us know if it works for you!
