Hi, I just run into this bug(? ) - I copied part of a screenshot to clipboard, went to Gmail and wanted to send it to someone. I used my simple text snippet at the start of the message, then pressed CTRL+V ... and it did nothing. No image is inserted to email body.
I tested it again, CTRL+V insterted image multiple times, then used snippet, and after it CTRL+V did nothing. It works correctly when copying raw text, however. But not with image data.
