Capital letter or small letter
Hello everyone,
I'm a newbie and just have started with Text Blaze. Hopefully someone can help me with the following.
I have a number of abbreviations that I use, but I would like them to start with a capital letter when used at the beginning of a sentence and with a small letter when used in the middle of a sentence.
Example:
Shortcut: _maw --> in other words
In other words:
What I mean is, in other words
How can I achiever this?
Jan
Hi @janbolhuis Welcome to the forum! :slight_smile:
You can try this command pack Text Blaze Dashboard Here's an example of how to use it for your use case:
{capitalize-match: in other words}
Then, when you're at the start of the sentence, you can type: _Maw, whereas when you're in the middle of a sentence, you can type: _maw. Depending on the capitalisation of the shortcut, you'll get the appropriate capitalisation in the output.
Let us know if it works for you.
Hi Gaurang,
Thank you very much! This works!!
Kind regards,
Jan
Thanks :grinning_face:
