Clipboard – Clipboard contents only as a selectable optional addition
How can I add the contents of my personal clipboard as a selectable option?
Normally, I copy a customer's name to my clipboard and then select a text snippet that begins with a salutation like …
"Dear Mr. / Ms. / Customer" and then includes the
"customers name" (but only if it's available, which isn't always the case).
As a beginner with Text Blaze, I don't understand this at all yet. I'm coming from aText.
Please give the snippet below a try.
  • It uses {formtoggle} to create a toggle field.
  • Then it uses {if} to create a condition for whether the toggle field is toggled on/off.
  • If it's on, then your clipboard contents are added in the snippet. If it's off, then I have it set to have a text field where you can just type the name (though you don't have to have that part if you don't want it).
Let me know if you have any questions :slight_smile:
Dear {formmenu: default=Mr.; Ms.; Customer; name=greeting} {formtoggle: name=Name from clipboard; default=no}{clipboard}{endformtoggle}{if: `name from clipboard`= no}{formtext: name=Name}{endif}
That's exactly what I need :star_struck:
This snippet should, in my opinion, be included in the standard demo snippets.
Thank you so much!
In addition to Dylan's excellent suggestion, here's another variation, where the text field is pre-filled with the clipboard contents:
Dear {formmenu: default=Mr.; Ms.; Customer; name=greeting} {formtext: name=Name; default={clipboard}}
Thank you very much, but I need the clipboard as an option, as the name is not always available.
