Hello, discover the tool a week ago and I'm finding it incredible. But I have a very specific demand. I have a data table in CSV format, separated by ";"
I have several columns, and very often I have to re-drain the data line by line.
Example:
content 1; content 3; content 3;
I have to reorder as follows;
content 1
content 2
content 3
Is there any way to do this tabulation, basing the separation on ";" ?
Maybe I found a bug ...
I was reading and rereading and its logic seemed correct. So I started to think that the problem could be elsewhere. The company I work for recently adopted the new Edge as their default browser, and that's where I've been using the extension. And for some reason, its formula works only on Chrome, not on the edge. It even appears in the preview, but is triggered when it is typed.
What ends up happening is that in the preview it works, and when I go where I need to use the command it doesn't seem to run. All others work normally.
