Combine AI snippets output with regular snippets
The Dynamic AI requests feature is awesome. It is much smarter than coming up with the prompts myself.
Is it possible to store the output in a variable and use it in other snippets?" I am thinking of using the "Import snippet" feature.
Thanks for your feedback. Can you give a specific example of your use case of how you want to store the output and reuse it later?
I am a Japanese internist and use an electronic medical record that runs on Chrome.
I am thinking of using Text Blaze to create referral letters. The fields in the electronic medical record, prescriptions, and laboratory data are all entered in different parts of the medical record, so I want to make the AI read each of them and summarize them to create a referral letter by combining them,
Then I need to combine the content created by the AI as variables.
Thanks again for your quick response.
screen shot
Of course the patient in the screenshot is a dummy.
Thank you for the explanation.
Can you elaborate on this? You are trying to combine the content from AI with what other content?
It is a combination of AI content and content that can be generated by regular Text Blaze commands.
For example, to create a referral letter, the patient's name, age, gender, etc. can be imported using Website commands, but the rest of the medical record content, such as summary and prescription extraction, requires the support of AI.
Thanks for the clarification. That is not possible right now, but it's something we want to support in the future. I have moved our discussion to Feature Ideas category.
I had a similar idea with our EMR but ran into the same issue. Let me know if you find a work around
