Hello
I'm confused as to why 2 snippets are conflicting but 2 others aren't (refer to image).
Is there a way to avoid conflicts that start similarly? In my case, they are feedback comments to a student - same topic, different feedback.
Thanks, Kylie
Hi @kashtc1x
Two shortcuts are in conflict when one of the shortcuts starts with the other.
In this case, the /doc
shortcut starts with /do
- which is the other shortcut.
To avoid this conflict, you can rename /do
to /do1
. Then, /doc
will not start with /do1
, and vice-versa.
In case you prefer to use this exact combination without conflicts, you can also change your folder trigger setting to wordbreak. Visit this link for more information.
Thank you
