Copy of snippet "26 Grade Focus (Positive & Uplifting)"
text blurbs MJ 8th
Hi {formtext}! :glowing_star::flexed_biceps:
I wanted to reach out and let you know how excited I am to work with you in PE! :man_running::dashing_away: You’ve already completed {formtext} assignments :memo:, and your grade is sitting at {formtext}% :bar_chart:. You have so much potential to raise that score even higher!
Your next step is {formtext}:woman_lifting_weights::sparkles:. Let’s take a look at your current grade together so we can pick out a few easy wins to boost your score and get it shining! :rocket::100: You can also resubmit any assignments tht are bringing your grde down for full credit!
Remember: USE, USE, USE the PE locker for all your PE help! :locked_with_key::backpack::key:
:link: https://canva.link/9xgabh44afr9mhq
Best,
Mrs. B from PE
