{note}{formmenu: default=good; mid; low; name=type} {endnote}{if: type="good"}WOW, {formtext: name=name}! You were absolutely on point during our discussion!
You confidently used math vocabulary and clearly explained your reasoning. You made great connections to real-world problems and showed strong preparation. You reached out responsibly, participated fully, and kept things positive and upbeat!
Check out your grading rubric below. Keep up the amazing work—you're crushing it!
Smiles, Ms Haid {endif}{if: type="mid"}Great job, {formtext: name=name}!
You showed a solid understanding of most concepts and were able to explain your thinking with just a little help. You made some real-world connections and participated well during our chat.
You were able to specifically speak on solving inequalities, real world situations with inequalities, and simplifying expressions.
With a bit more practice, you're on your way to mastering these skills!
Check out your grading rubric below. Keep practicing and asking questions—you’re almost at the top!
Smiles, Ms Haid {endif}{if: type="low"}Thanks for meeting with me, {formtext: name=name}!
I appreciate your effort during our discussion. Some of the topics were challenging, but you stayed positive and kept trying.
With more practice and support, you’ll continue to grow and get stronger with these concepts.
Check out your grading rubric below. Let’s keep working together—I'm here to help anytime! You’ve got this!
Here is how you scored:
Topic | Points Possible | Points Earned |
Content & Application | ||
Solving Inequalities | 15 | {formmenu: default=15; 12; 10; 7; 5; name=1} |
Real world situations with inequalities | 15 | {formmenu: default=15; 12; 10; 7; 5; name=2} |
Simplifying expressions | 15 | {formmenu: default=15; 12; 10; 7; 5; name=3} |
Preparation & Preparedness | ||
Responsibility, Appropriate vocabulary, & Actively Participated | 5 | {formmenu: default=5; 3; name=4} |
Total Score | ||
| 50 | {=`1` + `2` + `3` + `4`} |
