Copy of snippet "Jira Dev Comment"
Jira Dev Comment
Directly affectedIt is a list of the functions directly affected and they need to be verified
Indirectly affectedIt is a list of elements that could be affected with the functionality and it is necessary to verify that these works correctly
Developer notesA brief description of the work done at the developer level, this description helps us because if another developer needs to fix a related bug, they can see the work that was done and have a more specific vision of the problem
Work zoneWe will define the type of work performed, if it is Back End or Front End. In the case of Front End, define if the change deserves to be tested in different browsers and devices
Additional commentsAny additional comments you want to make. That is considered helpful for the team
