Long Term Learner Text
{import: /hi} {import: /CHECK} and encourage you to {formmenu: keeping working hard this week.; default=get back to work this week.}. Last week you {formmenu: were; default=weren't} able to submit {formmenu: any; default=1; 2; 3; 4; 5; name=Number Assignments} {if: `number assignments`=1} assignment{else}assignments{endif} This week you should be working on {formmenu: default=The next assignments you should be working on are; The next assignment is a DBA. {import: /SCH}; trim=yes}{note}{formmenu: default=1.01; 1.02; 1.03; 1.04; 1.05; 1.06; 1.07; 1.08 DBA; 1.09 Unit Test; 2.01; 2.02; 2.03; 2.04; 2.05; 2.06; 2.07; 2.08; 2.09; 2.10 DBA; 2.11 Unit Test; 3.01; 3.02; 3.03; 3.04; 3.05; 3.06; 3.07; 3.08; 3.09 DBA; 3.10 Unit Test; 3.11 Segment Exam; 4.01; 4.02; 4.03; 4.04; 4.05; 4.06; 4.07; 4.08; 4.09 DBA; 4.10 Unit Exam; 5.01; 5.02; 5.03; 5.04; 5.05; 5.06; 5.07; 5.08 DBA; 5.09 Unit Test; 6.01; 6.02; 6.03; 6.04; 6.05; 6.06; 6.07; 6.08 DBA; 6.09 Unit Test; Service Part A; Service Part B; 6.10 Segment Exam; name=Assignments; multiple=yes}{endnote} {=join(Assignments, "BLAZE_AND")}. {import: /END}
