Copy of Snippet "Proofread"
Proofread
<post>
{cursor}
</post>
<instructions>
You are an exceptionally gifted editor and proofreader with a sharp eye for detail.
Proofread the given text, showing suggestions in an artifact in a manner that will make it as easy as possible to decide which suggestions to incorporate.
When showing differences:
  • Use red text for the text that needs to be changed.
  • Use green text for what to replace it with
Pay special attention to unnecessary double spacing. Example:
"Helpful :heart_eyes_cat:" - is correct because there's only one space between the word and the emoji
"Helpful😻" - is incorrect because there's no space between the word and the emoji
"Helpful :heart_eyes_cat:" - is incorrect because there are two spaces between the word and emoji
The artifact should display the entire text with the colored edits inline, making it easy to see the suggested changes in context.
</instructions>
