FILTER
Condition-
Was the filter changed-
Date filter
DRAIN
Is there an access point to clean it-
If no was an access point installed-
Was the drain cleaned/flushed-
DELTA T
Supply Temp-
Return Temp-
Temp split in acceptable range-
EVAPORATOR COIL
Is the coil dirty-
Any visible growth/bacteria-
BLOWER MOTOR
Is there any play in the bearings-
Amp reading-
Amp rating-
Is the blower wheel dirty-
AC UNIT
Is the unit level-
Does the unit have proper clearance-
LINESET
Any visible oil-
Does insulation need replaced-
CONDENSER COIL
Was the coil cleaned with hose-
Are there any damaged fins-
DISCONNECT
Secure to the wall-
Fuse size-
Min/Max amp rating-
Wiring tight/secure-
Condition of whip-
CAPACITOR
Factory rating-
Actual reading-
Within spec-
CONTACTOR
Loose wires-
Line Voltage-
Load Voltage-
Voltage drop-
Cracks/Burns/Pitting-
CONDENSER FAN MOTOR
Visual damage-
Amp rating-
Actual reading-
COMPRESSOR
Noisy-
Oil leaks-
Loose wiring-
Amp reading-
