Copy of snippet "SCC Cooling Inspection"
FILTER
Condition-
Was the filter changed-
Date filter-
Take photo of condition and date-
DRAIN
Is there an access point to clean it-
If no was an access point installed-
Was the drain cleaned/flushed-
Take photo of cleanout-
DELTA T
Supply Temp-
Return Temp-
Temp split in acceptable range-
Take photo of supply and return temp-
EVAPORATOR COIL
Is the coil dirty-
Any visible growth/bacteria-
Take photo of actual coil condition-
BLOWER MOTOR
Is there any play in the bearings-
Amp reading-
Amp rating-
Is the blower wheel dirty-
Take photo of amp reading and cleanliness-
AC UNIT
Is the unit level-
Does the unit have proper clearance-
Take photo that shows the entire unit-
LINESET
Any visible oil-
Does insulation need replaced-
Take photo of line set condition-
CONDENSER COIL
Was the coil cleaned with hose-
Are there any damaged fins-
Take photos of any damage and photo after cleaning-
DISCONNECT
Secure to the wall-
Fuse size-
Min/Max amp rating-
Wiring tight/secure-
Condition of whip-
Take photo of fuse size & condition of whip and disconnect-
CAPACITOR
Factory rating-
Actual reading-
Within spec-
Take photo of rating and actual readings-
CONTACTOR
Loose wires-
Line Voltage-
Load Voltage-
Voltage drop-
Cracks/Burns/Pitting-
Take photo of voltages and condition-
CONDENSER FAN MOTOR
Visual damage-
Amp rating-
Actual reading-
Take photo of reading and condition-
COMPRESSOR
Noisy-
Oil leaks-
Loose wiring-
Amp reading-
Take photo of amp reading-
Recommendations-
