Activating Afterpay with Stripe follows a slightly different process from our standard onboarding. The good news is, it's more streamlined for you.
As an existing Stripe merchant, all you have to do is use the following link and complete your integration. If you need support for the technical integration, the Stripe team will assist.
Looking forward to working with you!
