Hi again,
Is there a way to count input for toggles?
The snippet below will give an error message when AWC1 and another option is selected.
{note: trim=right}{formtoggle: name=AWC1; trim=yes}{endformtoggle}{formtoggle: name=AWC2; trim=yes}{endformtoggle}{formtoggle: name=AWC3; trim=yes}{endformtoggle}{formtoggle: name=Store Closed; trim=yes}{endformtoggle}{if: `AWC1` and (`AWC2` or `AWC3` or `Store Closed`)}
{error: You can only select one option. Please deselect either AWC1, AWC2, AWC3 or Store Closed.; block=yes}
{elseif: `AWC2` and `AWC3` and `Store Closed`}
{error: You can only select one option. Please deselect either AWC2, AWC3 or Store Closed.; block=yes}
{endif}{endnote}
However, if I select AWC2 and AWC3 then we don't.
I can duplicate this but there must be an easier way:
{if: `AWC2` and (`AWC1` or `AWC3` or `Store Closed`)}
{endif}{endnote}
I have tried using the AI but apparently the if command won't count inputs and says:
"Cannot convert "no" to a number."
Please help!
