Hey Text Blaze Community ![]()
Using Text Blaze, you can perform calculations directly within your snippets to save time and reduce errors.
One cool example is using Text Blaze to create a creatinine clearance (CrCl) calculator, which helps you quickly perform calculations so that you can spend less time charting and more time with patients ![]()
Also, it integrates in any EMR (even if you switch EMRs). Give it a try and let us know what you think!
Learn more here.
Check out the calculator below:
Serum Creatinine (mg/dL): {formtext: name=scr} {note}Norm: 0.7 - 1.3{endnote}
Age (years): {formtext: name=age}
{if: `weight units`="kgs"}Weight{note} (kg){endnote}: {formtext: name=weight}{formmenu: default=lbs; kgs; name=weight units}{note} Norm: 1 - 150 kgs{endnote}{endif}{if: `weight units`="lbs"}Weight{note} (lbs){endnote}: {formtext: name=weight}{formmenu: lbs; default=kgs; name=weight units}{note} Norm: 2 - 300 lbs{endnote}{endif}
{if: `height units`="cm"}Height{note} (cm){endnote}: {formtext: name=height}{formmenu: default=inches; cm; name=height units}{note} Norm: 152 - 213 cm{endnote}{endif}{if: `height units`="inches"}Height{note} (inches){endnote}: {formtext: name=height}{formmenu: default=inches; cm; name=height units}{note} Norm: 60 - 84 inches{endnote}{endif}
Sex: {formmenu: Male; Female; name=sex}
Results
Original Cockcroft and Gault formula result: {=round(originalresult)} mL/min
Crockcroft and Gault formula using Ideal Body Weight: {=round(ibwresult)} mL/min
{if: bmi<18.5}Because BMI is under 18.5, it is recommended to use the unadjusted result.{elseif: bmi<25}Because BMI is between 18.5 and 25, it is recommended to use the Ideal Body Weight result.{elseif: BMI>25}Crockcroft and Gault formula using Adjusted Body Weight: {=round(adjustedresult)} mL/min
Because BMI >25, it is recommended to use the Adjusted Body Weight result.{endif}
{formtoggle: name=Show evidence and formulas}
Cockcroft-Gault formula for mL/min = (140 – age) × (weight in kg) × (0.85 if female) / (72 × SCR in mg/dL)
For Ideal Body Weight calculations, the following formula is used:
Males: 50+(2.3*(height in inches-60))
Females: 45.5+(2.3*(height in inches-60))
Adjusted bodyweight is calculated as Ideal Body Weight + 0.4 * (actual weight - ideal body weight)
BMI is calculated using 703*(weight in pounds/(height in inches^2)) for imperial measurements, and weight in kg/(height in meters^2) for metric.{endformtoggle}{note: preview=no}
Original research: Prediction of creatinine clearance from serum creatinine - PubMed, Impact of various body weights and serum creatinine concentrations on the bias and accuracy of the Cockcroft-Gault equation - PubMed
CALCULATIONS
Transforming units:
{kg=weight/2.2046 if `weight units`="lbs" else weight}
{inches=height if `height units`="inches" else height/2.54}
{meters=height*0.0254 if `height units`="inches" else height*0.01}
Ideal body weight
{maleibw=50+(2.3*(inches-60))}
{femaleibw=45.5+(2.3*(inches-60))}
Adjusted body weight
{maleabw=maleibw+0.4*(kg-maleibw)}
{femaleabw=femaleibw+0.4*(kg-maleibw)}
BMI
{bmi=kg/(meters^2)}
FOR MALE
{if: sex="Male"}
{originalresult=((140-age)*kg)/(72*scr)}
{ibwresult=((140-age)*maleibw)/(72*scr)}
{adjustedresult=((140-age)*maleabw)/(72*scr)}
{else}
FOR FEMALE
{originalresult=((((140-age)*kg)/(72*scr))*0.85)}
{ibwresult=((((140-age)*femaleibw)/(72*scr))*0.85)}
{adjustedresult=((((140-age)*femaleabw)/(72*scr))*0.85)}
{endif}{endnote}
