Create a formula
Hello,
I would like to know if it's possible to create a drop-down menu with hours (8 /10 /12), and linked the choice to another filed, where will add 2 hours to what I have chosen in the drop-down menu
Thanks
Hey Sebastien,
Is this what you're looking for?
{formmenu: default=8; 10; 12; name=hours}
Total hours: {=hours+2}
If not, please let me know what other field you want to add :slight_smile:
Yes, it's that.
Thanks :grinning:
And do you know what condition I must you use in order to put a text depending on the time of the day ?
Thanks
Hey Sebastien,
You can use the {time} command and the {if} command to do this. Here's an example:
Good {if: {time: H} < 12}morning{elseif: {time: H} < 17}afternoon{else}evening{endif}
Thanks for you reply
Have a good day
