Hello. When I try to open the Dashboard tab, the paged does not load. I have tried using Microsoft edge and Google chrome. I am able to use the snippets, but as you know, I need to have access to the dashboard to add a new snippet or update the ones I have.
Hi Jaime,
The dashboard should be working fine. It's possible it's an issue with your network. Would it be possible for you to try another network (e.g. if you are at work, at home, or vice versa).
If you are still seeing issues, can you email us at support@blaze.today and we can set up a call with you to look at it together.
I have the same issues with my desktop computer but not with my laptop and has been going on for a few weeks.
Hi @Leonidas_y Welcome to the forum! ![]()
Can you share a screenshot of the issue you're having?
Would it be possible for you to try to open the Text Blaze Dashboard on another internet network? For example: if you are at work, try to open the Text Blaze Dashboard on your home internet network. Or, try vice-versa.
Thanks it's working after following your suggestion to open to the home internet network.
