Data blaze formulas
Hello,
Is there a way to type in my own formula in data blaze? For instance I am wanting to search up how many times an input is counted on another table.
my goal is to try to see what shorcuts are coming up the most for each specific email address logged on the table.
@Gaurang_Tandon @AshwinMittal I have some tables in data blaze that I am wondering if I can either create snippets or formulas to read the data. I am looking to count how often a snippet is used from my tables data. I saw there is an option to use an AI but I don't have access to use that AI resource. Is there a different way to create a snippet that would count how often a snippet is on my table?
Hi @echapman,
Thank you for your question. Could you provide more details about your use case? It would be helpful if you could share a specific example to clarify your requirements. Additionally, I’m not entirely sure what you mean by the AI resource—could you elaborate on that as well?
