I'm using DataBlaze for information and document requests. Most times I require all rows to be inserted in the order setup within the database, other times, I'd like to manually select rows. Ideally, I would like a one click option to insert all rows while maintaining order.
I've tried grouping but that doesn't work.
Hi @latetotheparty,
If I understand your question correctly, you want to insert rows in a specific order. You can achieve this in Data Blaze by using the sort option. Sort on the Position
field which you add to each row. Here, I am inserting 3 rows in Data Blaze using a Text Blaze snippet.
This will insert all the rows on inserting your snippet in the specified order.
Let me know if you have any further questions.
Appreciate your solution Ashwin, but I realize that my initial post wasn't clear.
I have a snippet that's inserting rows from a DataBlaze table and would like the rows inserted into the snippet in a specific order from the table, ideally with one click.
I utilized your suggestion to add positions for my row and included 'ORDER BY Position ASC' to {dbselect} which allowed me to select the items in the right order.
However, I have a new question: Is there a way to make my button dynamically add everything from column 'Item' (it's currently hardcoded)?
{dbselect: SELECT Item FROM Table1 ORDER BY Position ASC; space=id; menu=yes; name=product_list;multiple=yes}{button: product_list=[["item": "Item 4"], ["item": "Item 3"], ["item": "Item 2"], ["item": "Item 1"], ["item": "Item 5"]]
; label=Add all Items}
{repeat: for row in product_list}{=row.item}
{endrepeat}
Yes, you can do that using our if-else command as follows:
That worked perfectly, thank you so much!
