It's great to see the Proper case formula in the beta right now.
Meanwhile, I've noticed that when I try to insert my Date snippet, often it first takes the format:
"it is June 25th, 2020, 5:28:34pm right now"
rather than the one in my account:
"25 June 2020 (Thursday)"
However, if I delete that text (sometimes I can't select the text) and then use the exactly same abbreviation again, it works properly.
Is there a default format that the program uses before the snippets are loaded. Let me know if there's a workaround for this.
