Would it be possible to make the menu width not be tied to the set column width but instead be a separate setting?
Example:
In the above, 99% of the time it is going to be a +1 phone. I don't want it to take up this much horizontal visual space. So I can add a cols field and set it to 10
This works well for the left right spacing, unless you need to select something other than the +1 field, then it becomes unworkable.
Could we get the best of both worlds?
