Hi.
I have had a quick look and couldn't find an obvious answer.
We are creating a decision tree but if we need to back track and change an answer then it will remember the other string of decisions and keep the output in the snippet.
For example:
Are both Meraki MX64s down?
{formmenu: default=; Yes; No; name=wan1}
{if: wan1="Yes"}
Please follow KB0039204 to check who the store's ISP [internet service provider] is.
Is the ISP British Telecomms?
{formmenu: default=; Yes; No; name=wan3}{endif}
{if: wan3="Yes"}
The issue is likely with the router. Please see KB00XXXXX{endif}{if: wan3="No"}
Follow the escalation path in KB0039204 to contact the ISP{endif}{if: wan1="No"}
Is the Primary Meraki running on WAN2 or cellular?
{formmenu: default=; Yes; No; name=wan2}{endif}
{if: wan2="No"}
The issue is likely with the Meraki MX64. Please see KB00XXXXX{endif}{if: wan2="Yes"}
s the Secondary Meraki on WAN2?
{formmenu: default=; Yes; No; name=wan4}{endif}
{if: wan4="Yes"}
The issue is likely with the router. Please see KB00XXXXX{endif}{if: wan4="No"}
Turn off the Primary Meraki by unplugging the power cable.
Has the store's connection speed improved?
{formmenu: default=; Yes; No; name=wan5}{endif}
{if: wan5="Yes"}
Reconnect the power cable to the Primary Meraki. The issue is likely with the Meraki MX64. Please see KB00XXXXX{endif}{if: wan5="No"}
Reconnect the power cable to the Primary Meraki. The issue is likely with the router. Please see KB00XXXXX{endif}
If we select "No" from drop down one, then "No" from the second drop down, then change the top to "Yes" the text from the second "No" stays in the output.
I want to make this idiot proof - so is there a way to stop this from happening?
