Default Snippet Settings (All Folders/Per Folder)
It would be extremely helpful to have an option to set default formatting options for any newly created snippets, such as font and colour. It would be great if this is available on a 'All Folders' or 'Per Folder' level.
Additionally, when setting a new default, there should be an option to apply to existing snippets within the selection (either all folders, or specific folders).
Hi @Lewis_Pilcher Welcome to the forum! :slight_smile:
If you set the font/colors as Default (which is the initial value for the new snippets), Text Blaze should pick up the font/color automatically from the target website's content. Can you please share if that works for you? If it does not, can you please share which font/color did Text Blaze miss and on which website? Screenshots would also be helpful :smiley:
Hey Gaurang,
Thanks for your reply! Is there a method to change the formatting of existing snippets in bulk? For example, if I have 50 snippets and wish to update the colour and formatting to be universal on all of these, is there a way to do this?
Thanks,
Lewis
There is no way to do that as of now. Can you please share your issue in detail? For example: which font you required, on which website, and a screenshot of the same would be helpful.
Hello,
The use case here is intended more just for easier management of multiple amounts of snippets, rather than requiring edits per snippet. For example, if a company has changed its branding or visual identity and wants to change multiple snippets at once to a different font and colour.
Thanks,
Lewis
