Disconnecting between devices with a Pro TextBlaze account
Hello,
I'm using TextBlaze with a Pro subscription, and I'm having a problem when I log into my account on multiple devices. It seems that if I connect to 2 devices it's fine. However, I get the impression that it disconnects me when I use it on 3 devices.
This makes it difficult to use, as I need to access my snippets from several computers simultaneously for my work.
Since I have a Pro subscription, I thought this feature was included.
Can you confirm:
  1. Is it possible to use a single Pro account on several devices at the same time? (How many? )
  2. If so, how can I avoid disconnections between devices?
  3. If this behavior is normal, what are the solutions for efficiently managing snippets on multiple computers?
Thank's !
PS: I work for a non-profit organization
You can use Text Blaze on multiple devices. However if you log out on one, it will log out on the others. That may be the issue you are encountering.
If you need to manage a group of people, we recommend our Text Blaze Business plan:
We have discounts for larger non-profits, you can reach out to us at support@blaze.today to learn more,
Thank you and congratulations on your work ! :grin:
