Hi, I'm struggling to get this drop-down menu to give me a blank space to enter other procedures that may not be on the list. I thought this would work but it doesn't seem to:
{note}Procedure:{endnote}{formmenu: default=Hysteroscopy; Smear; Curettage; Mirena insertion; Polypectomy; Endometrial ablation; Cervix biopsy; Vulva biospy; Anterior repair; Posterior repair; Total abdominal hysterectomy with BSO; Total abdominal hysterectomy without BSO; Laparoscopy; Other; name=Procedure; multiple=yes}{if:
Procedure="Other"} {formtext: name=Other}{endif}
Since you have a multiple-item formmenu, the results are provided as a list of strings. So instead of Other, the output when "Other" is selected is ["Other"].
What I would do is use the includes function to check if the user has selected Other. Here is the resulting snippet:
{note}Procedure:{endnote}{formmenu: default=Hysteroscopy; Smear; Curettage; Mirena insertion; Polypectomy; Endometrial ablation; Cervix biopsy; Vulva biospy; Anterior repair; Posterior repair; Total abdominal hysterectomy with BSO; Total abdominal hysterectomy without BSO; Laparoscopy; Other; name=Procedure; multiple=yes}{if: includes(Procedure, "Other")} {formtext: name=Other}{endif}
Hi Scott
Thanks it works, I've learned something new!
Only problem is that I want 'other' to be blank or replaced by the new text that I enter. How would that be done?
