I have this error message which I am confused because i had permission to the snippet before and i do not know what to do know, it does not show the owner of the snippet
Hi @Aldo_Barahona.
This message means the following:
Due to some security concerns, you are not allowed to edit folders with external connections until you are joined to the same organization.
If you were able to edit the same folder before, then that means either:
If you can find the "Share folder" button on the folder itself, then you may click it to check who the owner of that folder is. What you need to do now is to ask the folder's owner to let you join the organization, or try to duplicate the folder on your end if the snippets source is visible to you.
