Folders Not in Alphabetical Order - Create Easy Fix
Hi
Finding it very frustrating that when you create a new Folder it automatically goes to the bottom of the folder section. We work as a team, and there is no easy way to sort the folders by alphabetical order so that it is the same for the entire team. I know that you can go into the teams section and choose the default foders, but there is no easy way to sort these folders into alphabetical order (unless I'm mistaken) You seem to be able to drag these folders, but it's not user friendly. Anyone have any hacks around this?
Hi @Margot_Jefferson.
Thanks so much for your valuable suggestion. We'll think about it and let you know once we have any updates.
Thanks Abdalla
Hopefully an easy fix! When we created folders in Text Blaze initially, we did it all in alphabetical order so it was great. But now adding new folders, it's really hard to put them in order, and now it looks messy and unorganized. If there was a "arrange by" function, that would be amazing.
